Changed relay, but fridge stops cooling after 5 minutes. What could be the problem?
Los Angeles
HDR1040W
Magic Chef
My fridge was not cooling, so I change the relay. Now when I plug in the fridge, it starts cooling the freezer. The fridge thermostat turns on too, but then after five minutes the fridge thermostat turns off. And all cooling stops too. I'm not sure what could be the problem here? It is defrosted, no ice build up. I am a student, I have no experience fixing fridges, I was able to fix the relay thanks to Youtube videos. I just noticed that the fan does not run at all when turned on, is this what could be causing all the problems? I should replace the fan motor? Any suggestions on how to double check this would be greatly appreciated! Thank you!
HDR1040W does not pull up as good, please recheck it.
Click here: Appliance Parts
