Changing LED bulb on Frigidaire FPMO3077TF 30'' Built-In Convection Microwave Oven
DaCapitan
Louisiana
FPMO3077TF
Frigidaire
Hello,
I just had this microwave repaired(a part inside melted, just needed to be replaced). However, I notice now, when you open the door or use the microwave, the light inside does not work.
The repairman said it's possible the bulb has blown and will come look when he gets a chance.
That being said, I wanted to order a bulb, but the user manual doesn't mention the LED bulb type or how to replace it.
Can someone tell me the bulb type and the procedure for changing it?
I don't know that it is a separate bulb that can be replaced. Nowadays bulbs often come together mounted into a socket.
As near as I can tell it is Frigidaire part # 5304514246. I couldn't find many companies that stock it and can't even find a photo of that part!
DaCapitan
Louisiana
Tech guy came back out and tested and confirmed bulb was blown. Also believes that is the correct part.
Did you find any companies that stocked it?
DaCapitan
Louisiana
I ordered it from sears parts direct yesterday and it updated today to say on backorder, even though it had said in stock :/
That's too bad. It sounds like they need better inventory control.
You can try searching for yourself to see if you can find a supplier with stock or just choose a supplier to order it from and wait for them to ship it when they receive their stock again from the manufacturer. Everyone has to get them from the same place, Frigidaire's main supply chain. When they're out everyone will be out too eventually.
