- NS-CZ14WH2
- 1-5 years
Hello- I have a 14CUFT chest freezer that was not getting cold. It was determined the pressure was low as a result of a leak. When the closed system had a bullet piercing value added and the pressure tested, it was down in the green. So... I bought a can of 134a and attempted to charge the system. Can was held upright and when opened ( to charge the system ) it hardly moved the gauge at all. After a few tries I got impatient and started turning the can upside down and that is when the gauge started showing a reading and the PSI increased. I finished with PSI just at 1 and closed everything off. Assumed everything was fine. Copper coil going from compressor to the unit was same " cool " temperature as before. Not cold. This morning 12 hours later, freezer still not cooling. My question- was it bad to turn the can upside down when charging ? And any ideas as to why its still not cold ?
