FIXED Clock/Digital controls not working on my Samsung Oven FTQ3531WUW
mmcfagan
ny
FTQ3531WUW
Samsung
We moved our Samsung convection oven out of the kitchen in order to lay new floors. When we moved it back, the control panel would not light up and clock and oven would not work. However, the stove is working. We replaced the control board ($100) thinking that a bad circuit breaker may have blown the board, but still no digital display/clock/controls. Not sure how to proceed. Oven is only 4-5 years old.
Checked for power to the range?
220-240 volts AC black to red.
110-120 volts AC black or red to white.
mmcfagan
ny
Power coming in to range is good. Stovetop is working. Oven/digital controls not working. Can the ribbon cable on the board affect clock/digital controls and oven?
Checked for sure? The elements only need the powers to operate but the clock also needs the neutral.
FTQ3531WUW
That 1 one is an I ( eye )
FTQ353IWUW
Did you find the wire diagram from the range, if yes post a copy so we can have a peek.
mmcfagan
ny
Scanned the diagram ... hoping that you can open it. I believe the "I" may be an "eye" not a number 1. It's difficult to read.
mmcfagan
ny
Looking back at the voltage test, it looks like on the terminal block where the power comes in to the stove we get:
black to red 240
black to white -- nothing
white to red -- digital clock & control panel flashes on and off.
black to red 240
You have an open/loose white wire somewhere....could be in the house panel, cord plug outlet....good catch!
mmcfagan
ny
Ok... we'll try tracing the white wire. Maybe buying a new 3 wire power cord at local depot?
mmcfagan
ny
We check the breaker box again, and you were right! Loose connection from multiple contractors removing the panel. Oven is now working! Thank you!
