allknowing2012
- pds22mbsww
- GE
- More than 10 years
I am stumped .. Compressor is not coming on - no hum, nothing.
The fans are running - both at the condenser and the evaporator.
I have check and replaced the overload and the PTC. I have checked for resistance across the compressor 3 pins (doing it 2 at a time). Also checked for shorts to ground.
Temperatures in the fridge are reporting room temperature - its been dead for a couple days now.
In diagnostic mode is shows O - 2 and O - 5. Which if I understand correctly means fail on FF2 and fail on Freezer. Looking at the motherboard - I dont have a wire for FF2,
so I figure that is fine. The Freezer one has me puzzled. I initially thought that was the evap resistor and cut it out - found it was actually #4 in the diag test so now it flagged that.
I put that resister back in and cleared the O4 condition. So what is Freezer thermistor?
Is it the one hiding in the side of the freezer (bottom freezer)?? I checked at the J1 (removed from motherboard) and it seems to be reading okay resistance - 5K ish for 72F.
Anything I can test before caving in for a new fridge or having an expensive service call?
Where can I place my AC volts probes to verify if compressor is getting voltage? I tried between overload and pink - got nothing.
Any tips - searching and watching lots of vids on this but have reached a dead end.
Daryl
Daryl
