mincind
- EIMED60LT
- Electrolux
- 6-10 years
I started with an E64 code (which has been addressed 5 or 6 times in the past 8 years with a new element.)
After installing a new element, I started getting an E65 error. I found the inlet thermal limiter was in fact tripped. I replaced it and the high temp thermostat. Dryer ran 10 minutes before tripping the thermal fuse. Replaced fuse and it did it again.
(And the vent system has never been cleaner - no blockages.)
So....I installed a new control board and same thing again. Arrrrrghh!! $225 more and still no fix.
With nothing else to change, I replaced the element a second time.
I was actually able to dry two loads of clothes and thought issue was solved.
On the third load.....no error codes and load finished, buy clothes were still wet.
Tore the machine apart for an 9th time thinking I would find a blown thermal fuse...but it was fine.
I finally decide to go in diagnostic mode.
If I did not see it, would not believe it. When the inlet thermistor hit only 114 deg F, the dryer stopped for E65. Outlet thermistor reading about 72 degrees. Could the replacement high temp thermostat also be bad?
So I went back to the original one.....and guess what.....was able to see the inlet thermistor hit 225 degrees and no E65. Successfully ran ONE load.....and then same thing. Diagnostic mode show throwing E65 code when inlet thermistor only around 110 deg F.
For S&G, tried to run a load the next morning.....and dryer worked. Successfully ran 3 loads of clothes..........but now the dryer is again not heating. Same thing as seen before, showing E65 in diagnostic mode when inlet thermistor is only at 110 - 114 degrees.
Help!!!! I am ready to lose my mind. None of this makes any sense.
