FIXED Continued F1E1 code on Whirlpool Wall Oven WOS51ES4ES00
bpochon
Nebraska
WOS51ES4ES00
Oven finished a clean cycle and display was lost and door was locked. Here's what I've done since then:
  • Replaced thermal fuse. This restored display. Next, I found out the oven wasn't producing heat.
  • Entered into diagnostic mode. Error F1E1 displayed and "check P1-K2 Upper Bake wiring" and "check P3-K1 Upper Broil wiring" displayed.
  • Installed new oven control board per tech sheet's guidance (when F1E1 error is thrown) and checked continuity on upper bake/broil element. Continuity good.
  • Cleared codes via diagnostic mode.
  • F1E1 appears again along with "check P1-K2.... P3-K1" and now F2E1, which is stuck keypad.
Any direction?
Brady
Hi Brady,
For F2E1, the tech. data sheet does not mention anything on how to test the keypad assembly, so all you can do is replace it:
For Continued F1E1 code--->Did you ohm test your safety thermal thermostat that's located in the very back?
You will want to first ohm test your safety thermal thermostat, its #34 here:
You'll need to pull your oven out from the wall, then take off the back access panel, then you will need a multimeter, then take off the wires to it, and ohm it for continuity.
You may need to get someone to help you pull it out as wall ovens are very heavy to pull out by yourself.
Unplug or turn the breaker off to your oven first before ohm testing that safety thermal thermostat!
Here's the safety thermal thermostat for your model you can order if needed:
W11034459 Thrmst-Fix
bpochon
Nebraska
Thanks, Jake. I will pursue the thermal thermostat next as it was mentioned when I first started researching.
Ok sounds good.
bpochon
Nebraska
To wrap up this thread, it ended up being the thermal fuse and thermal thermostat. After replacing these two, oven is functioning.
Glad to hear those two parts fixed it.(y)
For others following your thread, here's the thermal fuse for your model that will restore the display:
W11025102 Fuse-Thrml
