FIXED Convert black SHS863WD6N to Stainless SHS863WD5N
Stevesul
Western NY
SHS863WD6N
Bosch
Reposting this because the admins said the original thread got corrupted.
I converted a 15 month old black SHS863WD6N to Stainless SHS863WD5N to match a new fridge and range.
The two parts were
00772674 Door-Outer
00775770 Panel-Facia
The Fascia was backordered and I put the stainless panel in last week. It's best to do them at the same time though as I ended up taking off the panel for the fascia.
Panel is easy...just six screws. You just have to align it on the bottom and slide under the fascia. Peel the protective film off an inch on the sides before attaching to make it easier to remove.
Fascia you just need to carefully remove the power button and three other wiring harnesses. The wires are tucked under clips neatly.
Easy swap for about $160.
Excellent Steve, good job, looks really good.:)
