CSHS5UGXC Water Dispenser does not stop pouring water
modemmex
Brooklyn, NY
CSHS5UGXC
Howdy - when I use the water dispenser the water pours out for a moment after I pull the glass away. This started about 2 years ago. It hasn't gotten worse nor better. I'm finally getting around to trouble shooting. I'm convinced I can fix this myself. thanks in advance!
  • GE_Refrigerators.pdf
Water tank/reservoir can "breath" or flex and push out some water.
Low water pressure can prevent the fill valve(s) from closing properly.
Bad fill valve not closing fast enough or properly.
Filter head.
Would have to be investigated.
If needed:
Water-Tank-Assembly-WR17X11440--00680472.jpg Water tank in refrigerator for chilled water dispenser
Water-Inlet-Valve-WR57X10070--01045684.jpg Water valve
