CVM2072SM1SS GE Cafe Microwave Dead
JuzFixIt
Philadelphia
CVM2072SM1SS
Had a power surge and now microwave is dead. Model #CVM2072SM1SS. I changed out the 2 fuses up top, and the 2 thermal fuses, and it’s still dead. Any other things I should be looking at or testing?
Check the outlet?
If yes, what was the meter reading?
Has anybody tested for power coming into the unit?....a power surge can damage things like the board so the unit would act dead.
Checked the oven liner thermal cut off?
How do I check if power is coming in?
Volt meter.
Follow the cord plug coming in. L and N.
There is a trouble shooting flow chart on the tech sheet bb left for you.
JuzFixIt
Philadelphia
For some reason I can’t open the tech sheet. Will the microwave have to be taken down to test it? How do I test the control board? Thanks again!
JuzFixIt
Philadelphia
Openeded. Do i need different thermal fuses for the Hood and Bottom? i used the same for both. And where are the other 2 TCO's? I'm not great at reading these diagrams, how do i test for voltage at LVT on PCB?
B ( LVT Low Voltage Transformer ) near the 1 in the circle and second W ( secondary relay #1 ) near the 5 in the circle would test for 110-120 volts to the board....and test all the tco's and fuse at the same time.
