CWG4020 Maytag burner valve
glowskit
michigan
CWG4020
I need a burner valve for a Maytag oven model #CWG4020 LP gas. I think the part # is 7501P134-60.
Any one with one or anything not will work.
Tom G.
If you get a chance, let us know how you make out with it.
Joshhud
Delaware
Any update here? I have a leak too but would like to fix it and continue using the oven. Can I use the 7501p133-70 part instead?
Joshhud
Delaware
1. So can there not be an update because it's from 2014? I have the same issue and would like some help.
2. Sorry it should be -60 not 70 does that help your search where you provide no help?
You would likely have a better success making a new thread than piggy backing on a 4 year old one.
Sure it does!....but I will keep that my help to myself.
Josh, If you piggyback on an old thread the only person that's going to see it is jeff1 and maybe the original poster. No one else is subscribed to it. By starting a new thread all the techs on this site will see it along with other members that are having gas range issues. That way we can ask stupid questions like, do you have the exact same model? Or, are you sure that's where your leak is? Or, are you sure you even have a leak ?
