CYE22TSHPSS GE Cafe fridge is at 68 degrees and the temperature is not dropping.
bucboy76
New York
CYE22TSHPSS
I have a GE Cafe fridge - model CYE22TSHPSS
It's about 3 years old. The freezer is fine.
The fridge is at 68 degrees and the temperature is not dropping.
How would I know if the problem is for sure the evaporator fan?
I did take off the inside back and i dont see much ice build up..
I had this problem on a customers Refrigerator in Parker, Arizona last month, its the Fresh Food evaporator fan motor that is bad if you don't hear it running. I replaced it and its running perfect!
Here's the Fresh Food evaporator fan motor for your model you can order:
WR60X26866 Refrigerator Evaporator Fan Motor
There is a video in the Fresh Food evaporator fan motor part link that shows you how to replace it.
If you want to verify that--->Use a multimeter to check the fan motor voltages.
At the electrical connector at the FF(Fresh Food) Fan motor inside the Fresh Food(Refrigerator) section, when the FF Fan is NOT running:
RED to BLACK - 12 VOLTS DC CONSTANTLY
If you get 12 VOLTS DC CONSTANTLY when it should be running and its not running, then that fan motor is bad.
Your welcome, let us know how it goes.:)
