jboling
- D8200
- Maytag
- 6-10 years
I have a model D8200 dryer. It was originally installed in an apt I had that was an older building and apparently had the older three prong outlet. So when they installed it they put a three prong plug power cord on the dryer instead of the four prong one it was designed for. I didn't fully realiize this until reading the installation manual recently and realizing that was an option the installers had. I guess the other option would have been to put the four prong cord on the dryer and use an adapter? I honestly don't know.
I have since moved and now the outlet is a newer 4 prong outlet. But I now have a newer-ish model dryer but with a 3 prong plug power cord attached.
What is recommended? I'll be totally honest, I am not knowledgeable on this so some of this info may seem off or what I need to do may seem obvious.
Do I need to get an electrician or Maytag tech out to change out the power cords? Or would it be ok or even safe to use an adapter to take this model dryer from using three prongs back to the four prongs it really should be using? Any and all help is appreciated.
