Dacor microwave door spring not staying closed - spring
cdippold
Cincinnati, oh
PMOR30B
-major brand-
Less than 1 year
I have a dacor over the range microwave that the door will no longer stay latched closed. It appears that the spring on the hook latch of the door is broken/ not working. Is this an easy fix? All else still appears to work fine with the electronics/timer stuff. But since the door doesn't latch closed, it won't let the microwave itself work.
Thanks, Carrie
