Danby Silhouette Select DWC93BLSST Wine Fridge No Longer Cools
Sylvurfox
North Vancouver, BC
DWC93BLSST
-major brand-
Hi All,
I have a Danby Silhouette Select DWC93BLSST wine fridge which no longer cools. The interior lights work, the thermostat display is on, the interior evaporator fan runs and the cooling fan for the condenser coils runs. The condenser coils are clean. I can hear the compressor relay click on and feel the vibrations so assume the compressor does run. After about 20 minutes the compressor gets hot enough that you can't leave your hand on it for more than a second or two. Is there anything else I can check? Is this a coolant leak / lack of coolant issue? Is it possible to repair or recharge?
Any help would be greatly appreciated.
Thank you.
