Danby Wine Cooler, Not cooling
xybercoke
Edmonton
DBC514BLS
Hi I have a Danby wine cooler, model DBC514BLS
The fridge is not staying cool. From what I can tell all the fan are running, the power works ok. And I can change the temperture on the display. I brought it in from my freezing cold garage today. And i set the temperature to 4°C and it started out at 12°C. after 30 min it went up to 13°C than to 14°C I believe the thermometer is correct.
There is a clicking sound coming from the back, every few minutes. and when i put my hand on the compressor it was very warm.
What do you think the problem may be?
Sounds like a compressor not starting issue....bad relay/overload, bad compressor, low voltage from an extension cord, bad compressor.
xybercoke
Edmonton
Is it possible to order a new relay and try that first see of that fixes it. There is no extension cords, and a bad compressor is expensive to fix i believe.
These units are a Chinese built product, many parts are not available.
I did find these at RC...
Start-Device-QP2-4-7-01472068.jpg LINK> PTC starter, *Note: Part may have one terminal or three. Either version will function the same.
Compressor-DG1-69-01313024.jpg LINK> Compressor
Labour on compressor change can be $150-200+
