DBC039A1BDB Danby Beverage Center Not Cooling Below 50F
jtflorian
GA
DBC039A1BDB
Hi, I'm new to the thread. I searched but could not find the answer to my problem. I have a Danby Beverage Center (4.5 cu ft mini fridge) that will no longer cool below 50F (normal down to 39F). The compressor runs full time and gets hot over time. The coils inside the fridge get cold and the fan is running and blowing cold air. I have tried unplugging and let sit for several days but this does not help. Is it possible there is something wrong with the control board? Does it have a defrost mode that might be stuck on? Does this have a condenser fan I am not aware of? Or is it more likely that I just lost some of the AC Charge (R134A). No fittings to test Hi/Lo pressures. I'm not much for soldering fittings on but I'm willing to try if that is the most likely cause (I've done basic auto AC). Worst case, I wouldn't mind paying someone to install fittings and add new charge. Thanks for the help, Jeff.
If it is running, not likely.
You mentioned it is running, nope. The unit goes off during a defrost cycle.
Probably does, but can't check as most online parts places will not have this units part breakdown. I will try to remember to check our Danby CD at work on Monday.
A system problem is very likely...but a leaker is just one issue, restrictions, inefficient compressor or a leaker or possible.
jtflorian
GA
Thanks Jeff,
Here is the schematic they sent me.
I don't think a defrost cycle exists since it doesn't have a freezer section, but my thought was that if it did, it is turning it on even though the compressor is running, and won't turn off, so it is always heating. Cooling seems cold enough to cool, condenser coils are hot like it is removing heat from inside.
jtflorian
GA
Parts list from schematic
Danby Model: DBC039A1BDB
Factory Model:
Effective Date: 2012/11/13
Revision: New
NO PART NUMBER PART DESCRIPTION (ENG) QTY Notes
1 DG2-1 Power cord 1
2 DG13-1 Water tank 1
3 DG1-29 Compressor 1
DG12-102 Start device 1
DG12-96 Overload protector 1
4 DG13-2 Electrical box cover 1
5 DG11-2 Junction block 1
6 DG26-9 Cabinet 1
7 DG13-8 Decorative nail 3
8 DG14-1.2 Top hinge module 1
9 DG13-12 Decorative cover 1
10 DG13-7 support block 1
11 DG20-1 Wire clamp 1
12 DG12-1 Evaporator 1
13 DG8-7-W Senser 1
14 DG7-3.1-BH Evaporator fan 1
15 DG19-1 Fan cover 1
16 DG22-132 Air duct board 1
17 DG3-7 PCB board 1
18 DG6-8 Transformer 1
19 DG3-14-B LED light 1
20 DG9-3 Switch 1
21 DG14-20 Covering of lock arm 1
22 DG23-6.7 Door 1
23 DG14-3 Extrusion-board of lamp switch 1
24 DG15-105 Cylinder wine rack 1
25 DG15-100 Full glass shelves 3
26 DG15-102 Front bar 3
27 DG15-103 Back bar 3
28 DG13-146 Dowel 6
29 DG20-63 Display panel 1
30 DG22-22.2 Electrical box 1
31 DG13-6.2 Cabinet leg, type BC50N 1
32 DG14-166 Lower hinge module 1
33 DG9-9 Door switch 1
34 DG14-26.1 Switch box of door lamp 1
35 DG13-6.1 Cabinet leg, type BC50 3
36 DG12-6.1 Air circulating pipe 1
37 DG22-89 Compressor bracket 1
38 DG13-215 Door stopper 1
39 DG14-125 Handle 1
40 M184-008 Gasket 1
41 DG11-4 Drier filter 1
DG14-5.1 DWC DOOR LOCK KEY LONG
No condenser fan motor.
From the picture, it is a cycle defrost...when the compressor cycles off the fan is still drawing air over the evaporator and this warmer than the evaporator air will defrost it....so it defrosts when the compressor cycles off.
dhern55
Southern Cal
Hello, I'm also new here. I have the same mini fridge with the same problem. Was there a fix for this?
David
