DBXR453ET3WW GE dryer on/off switch
pamelaw72
DBXR453ET3WW
I have a 10 plus year old GE dryer. The rotating on/off switch broke off and I ordered a new one. I took a picture of the wiring but cannot find it now. It is a 2 prong switch; a prong on the top with the number 1 next to it and a prong near the bottom side with the number 2 on it. There is a red wire and then a brown wire and off white wire that combine to fit on one prong. Can someone tell me where they go please??
pamelaw72
The switch you show is correct. I connected the wires, brown with the piggyback on 1 and red on 2. When I turned the dryer on sparks flew out of the panel :( Now I am totally scared to mess with it.
pamelaw72
The sparks came from the timer control. You have to turn it to a setting first before you turn the on/off knob. When I turned the timer control, sparks shot out from the back of the timer control.
Possible bad timer....but more possible a wire came off during your inspection/repair and it is touching something else or maybe a wire connector bent over and is touching another wire during your inspection/repair....I'd check ( power off ) that as a good place to start.
pamelaw72
The dark brown wire with the piggyback goes to the control knob. The red and light colored brown run down into the machine.
