DDT595SSJ0SS Wont Drain
RBurks
Maple Valley
Model
DDT595SSJ0SS
Less than 1 year
I washed our dishes over the weekend and noticed when I went to unload the dishes that there was a bunch of water in the bottom still. The load I did had some grease in it which could have clogged something up. I don't know where to start troubleshooting. If I remove the flood float it will drain if I push down on the white tab on what I would assume is the sump pump. I wanted to avoid removing the entire unit and taking things apart.
Any suggestions on what to check or what to clean or how to test if the sump is working properly?
Thank you,
RYan
Hi Ryan,
If your dishwasher is Less than 1 year old, contact GE to come out for free under warranty: 1-800-432-2737 to fix it for you, you don't want to fix it under warranty or GE can void your warranty.
RBurks
Maple Valley
the serial number is scratched off. I think it was a remanufactured unit which I would assume isn't under a warranty. I didn't buy the unit. It was brand new in place when we bought the house.
Ok,
Here's the service manual for your model: https://drive.google.com/open?id=1M-G9W3HiaYnihdB5Cy-jfSPoVf8DZ7j7
The drain pump section starts at page 65 check all those parts it illustrates to see if you have a grease clog. I'd also check the fine filter and coarse filter on page 56 for a grease clog.
