FIXED DDT595SSJSS GE Adora - needs new control board already? randomly beeping, control panel died
elainek
TX
DDT595SSJSS
Our GE Adora dishwasher is only 17 months old. A few weeks ago, the machine started randomly beeping at us several times a day and then, after about a week of that, the control panel just died. It wasn't the breaker, so we called a repairman. It was a $99 service fee to have him come out and tell us it needs a brand new control board which would cost us $400. We only paid $500 for the dishwasher to begin with, so If I can't fix it for less, I won't bother. My questions are:
- Isn't it really young to already need a new control board? Is there anything else we could try?
- We would love to find a replacement part for less than $400 if you can help point us in the right direction.
Thank you!
Sounds like it could be the control board.
It costs less than his service call. It's located under the machine on the right side.
Nick657
CA
Did this fix your problem? I have the same model dishwasher and it's a few years old. Been working perfectly and noticed some random beeping as well for the last week or so. Went to start it last night and no response at all from the control panel. Should I go straight to replacing the control board or check a few things first? Thank you
There is a digit missing in the model number he posted.
DDT595SSJ0SS
DDT595SSJ2SS
DDT595SSJ4SS
All 3 of those model numbers takes this one:
DDT595SSJ5SS takes this one:
Nick that one you posted is the UI Board, not the main control board, which one do you need?
Also please post your complete model number. The model number tag is located inside the door on the tub frame.
Nick657
CA
Model # DDT595SSJSS
I am not sure which one I need at the moment. Will check power and voltage this afternoon. Was just doing some research first and ran across this post.
Thank you
Nick, You're missing that digit between the "J" and the "S" --->DDT595SSJSS
DDT595SSJ0SS
DDT595SSJ2SS
DDT595SSJ4SS
DDT595SSJ5SS
Take a photo of your model number tag and upload it here please.
Nick657
CA
Sorry about that.
Ok, from your photo of the model number tag, yours is DDT595SSJ0SS
--->Here's the main control board for your model: WD21X24901 Machine Control
Here's the user interface(UI) board for your model:
WD21X23461 Kit Svc Ui Top Logic
--->Check your main control board STATUS LED, Tell us how many times its flashing in a row. Make sure you keep the electrical connectors connected to it when viewing it.:)
To access it:
Nick657
CA
Checked that earlier and found a solid green light. Checked voltage on the control board like you had posted on other posts and I kept getting a reading of 14.2. Will double check voltage again tomorrow
Ok, if you get 14 Volts DC on the control board pins to the UI Board and the buttons are not lighting or responding you will need to order and replace that UI board.
Nick657
CA
Ok thanks. That’s what I was assuming from reading your other posts. Did you have a video on how to replace the UI board? Thanks for your help.
This is the only video that comes close to replacing it that I could locate:
Nick657
CA
Replaced the UI Board this evening and put the door back on and plugged everything in. Light stayed green on the main control board and still no response from the buttons.
Did you set the personality jumpers per the instructions that came with it? If not, you MUST do that or it will not work.:)
If you did set the personality jumpers and its still not working, Lets verify the voltage again:
This time also verify the Voltage at the UI Board per that diagram above.
Nick657
CA
Nope never heard of personality jumpers before this. Need to see if any instructions came with the box. I didn’t see any the first time. But will look tomorrow. How do you go about setting personality jumpers??
Nick657
CA
Thanks for all your help and patience. Pulled it back out and moved the jumpers and it works perfect so far. Funny thing is the old board doesn’t have that jumper. Is that normal or is maybe that why it broke. But it is fixed now. Thank you
Excellent Nick, good job setting the jumpers properly to get it to fire up and work good now. (y)
That's a good question, but I don't know.
