DFUD042 Viking pro dishwasher not spraying or circulating water
Daddy fixes everything
NEW YORK
DFUD042
Hello
Just started having trouble with my Viking dishwasher. It turns on it goes through the drain cycle immediately which is normal after the next click the sprayers would normally turn on but it's not spraying or circulating water. The motor is spinning freely on the circulation pump so that's not blocked. I'm wondering if anybody here has had any similar situation. Any information would be much appreciated.
Call Viking and set up a warranty service call. Everything is covered for the first year. If you attempt a repair you risk losing your warranty.
Try to locate the tech sheet and run the service diagnostics. It's most likely behind the lower panel.
