PeterAv
- SVD48600P
- Jenn-Air
- More than 10 years
Older model JennAir dual fuel SVD48600P 240V range. Bottom baking element will not heat, but top broiler element does. Removed element and tested continuity at 30 ohms. Plugged in the (working) broiler element into the bottom baking leads and still no heating. I tested voltage at baking element leads and get (strangely) 51V even when the oven is off (0V is circuit breaker is off fortunately!) If I then turn the oven on, I hear a relay click a few seconds later, but still same 51V. About a minute later there is a double click of relays and voltage jumps up to 62V. But 5 seconds later there is another double set of relay clicks and voltage drops back to 51V. Pattern or relay clicks/voltage swings between 51V and 62V then repeats every minute. Any suggestions on what to test next. I fear a bad relay board since they seem to be not available for this model anymore. But wondered if something else is going on since I do hear relay clicks occurring.
