Discontinued Door Clooser Assembly
gogo90272
LA
KSSS42MDX03
Both my my door closer assembly parts are bad (Kitchen Aid Part 1112992 or repair clinic Part 302319). The problem is that the nylon bushing that holds the hing pin is stripped on the freezer and broken on the fridge side. The part is discontinued and I need help.
I did some digging and found Sub Zero has similar closers (part 3540270, 2805801 and 3540810). Of the three 3540270 seems the most promising (dimension wise when overlaying the images on top of each other). Has any one got the expertise with SZ fridges or even has one lying around that might be able to confirm part acceptability?
Thank you in advance.
I'm not sure if its compatible or not.
@dimahot888 does a lot of Sub Zero units, he may be able to assist you on this.
abbyr123
Georgia
Hello! I am running into the same problem and wanted to see if it ended up being compatible? Where there any modifications that had to be made?
This thread is 10 years old, I doubt you will get any response.
