- DW80J7550UG
- Samsung
- 6-10 years
I have a Samsung Dishwasher that when I try to run a cycle it will run for 1-5 seconds then beep and it won’t go any further. So then I turn off the dishwasher and unscrew the drain hose from the garbage disposal and put it into a bucket and let the water that’s in there drain into the bucket (which isn’t much). Then I reconnect the drain hose and turn the dishwasher on start it again and it completes a full cycle. I have pulled it out and seen if there was anything stuck in some of the components and there was nothing. Checked the lines and nothing. Try to run a diagnostic mode and I get Code C1. I called Samsung and they did not have much information. Except there might be a clog in the drain hose but I checked and there was not.
