Display has gone blank and unresponsive, old GE range
prouss
United States
JMP31WW1WW
The LED display on my old General Electric electric range has gone blank and unresponsive and no clock. There is currently no display to see an error code
Pressing the buttons no longer does anything. I can't turn on the oven.
The stove-top works fine. The stove-top have a working indicator light.
Just the LED display is out of commission, the buttons that control the oven do nothing.
I tried the main breaker in the fuse box of my house, disconnected power for 15 minutes and repowered w/ no success.
The model number that is located inside the oven door is:
JMP31WW1WW PN PLT-135-3
I'm hoping this is just an internal fuse issue like an a thermal fuse protector. Is there any fuse buried somewhere in the oven?
Can anyone help?
JMP31WW1WW
JMP31
Dsiplay
ERC
Nope, no fuse.
Sounds like your clock oven control board has gone bad. If you have a multimeter you can confirm this by testing for 120 volts between L1 and Neutral on the control board wires. If you do this be careful not to touch any other wires or you will get shocked.
It's No Longer Available: Oven Control Board WB27K5140
