Display issues: Samsung Microwave SMH2117S?XAC
George SURKO
Ottawa, Ontario Canada
SMH2117S/XAC
Samsung
The DISPLAY is not functioning well..pixelated as in photo.
Every other function works perfectly
Do I need to replace the main PCB board assembly DE92-02135B or is there a separate display board?
Any thoughts?
George.
SMH2117S/XAC
XAC is Canadian....most (all?) online will be XAA for USA.
Is there anything else after the XAC?
SMH2117S/XAA-01
SMH2117S/XAA-02
I found above online.
jeff sr.
Might want to confirm with Samsung Canada.....but I found the same part# as you did.
DE92-02135B using SMH2117S/XAA-01
I had: Samsung Canada 1-800-726-7864 or 1-855-254-4747 Canada
jeff sr.
