FIXED DLEX2450R LG Dryer only works on timer, not sensor
danjhill
Beaverton, Oregon
DLEX2450R
LG
When I try to dry normally for sensor drying....it starts on 40 minutes, but then goes to 2 minutes. I can dry with the timer. Bad sensor?
It is an upright unit.
Its Possibly a build-up of fabric softener on the moisture sensor bar, below your filter housing, that's causing this problem, use rubbing alcohol on a cloth to clean the moisture sensor bar first, and see if that resolves it.
Here's the moisture sensor bar for your model:
6500EL3001A Moisture Sensor Bar
Let us know what happens.
danjhill
Beaverton, Oregon
Jake... thanks very much! 2 things... just as an FYI we do not use dryer sheets.... and from what I can tell, (utube) it requires a fairly involved process to remove most of the top and front of the cabinetry to get to the sensor... is this correct?
Do you use fabric softener in the washer? I'd try to first clean it with rubbing alcohol first no matter if you use fabric softener or not.:)
When you click the sensor part link I posted above you will see a video on how to replace it.
danjhill
Beaverton, Oregon
I just looked at another video... MUCH easier!!!
Jake....just cleaned the sensors with IPA, it did the trick! You da man!! Thanks so very much...just saved me a $100 service call!
Excellent Dan, glad to hear that. (y)
danjhill
Beaverton, Oregon
Jake.... It appears that the sensor drying issue is intermittent .....so I am expecting that at least one of the sensors is bad....In this case, I am guessing that I would just replace both beings as they are cheap.... Thanks again for your help.
Yes Dan, replace them both.:)
