DLG7188 LG dryer intermittent heating problems
Matiebean
California
DLG7188
LG
My LG gas dryer was full of lint which I’ve removed, I’ve gone through the control panel tests, checked continuity of the thermal fuses and they’re okay.
The dryer doesn’t want to heat on timed dry settings for certain. The wiring harness that connects to the gas burner valve assembly is a bit singed.
Is there a way to determine if it’s the connector or the gas burner valve assembly?
I’d attach a picture for review if I knew how.
We need the complete model number first.
Here's the results I get:
DLG7188RM (ACREEUS) - Dryer
DLG7188WM (ABWEEUS) - Dryer
To upload photos--->Just Click "Go Advanced" at the bottom right side of this Quick Reply editor that we type in, then you will see the MANAGE Attachments Button.
