DLGX5681W Samsung Dryer - Says it is drying but does not tumble or heat
mountainbiker33
Valparaiso, Indiana
DLGX5681W
Samsung
This Samsung dryer will turn on, allow me to select a cycle, but when start, it won't tumble. The display says it is drying but it just sits there. I am at a loss. Thanks for your time, guys!
Matt
Hi Matt,
Do you hear any sound at all when you press start?
If not, Let's start with the door switch first. You will need a multimeter to ohm test it.
How to use a multimeter to test video.
Make sure the dryer is unplugged while ohm testing parts.
Here's the door switch for your model:
Door Switch 6601EL3001A
This video shows you how to access it:
This video shows how to ohm test it:
If the door switch is good, then check for a broken belt, because you have a broken belt switch on this model, if the belt is good, then ohm test the broken belt switch.
Here's the broken belt switch for your model:
Belt Switch EBF61734701
There is a video in the part link that shows you how to access/replace it.
Ok, yes ohm test those parts. Also ohm test the blower thermostat, it is on the backside of the blower housing assembly.
Here's the blower thermostat for your model:
Thermostat 6931EL3002M
Also check the wire connector at the motor, another person found a burnt wire there:
If they are all good, then its a bad control board.
