dlagrainge
- DMT800RHS
- Samsung
- 6-10 years
My dishwasher will run for about 20-30min and then display an SE error. I have deduced that this means there is an error with draining and that is evidenced by the water in the bottom of the dishwasher.
I pulled the dishwasher out, unplugged it, and disconnected the drain hose. I took a part the assembly in the base of the dishwasher, draining all the water and collecting any debris. I used some baking soda and vinegar through the drain tube and have confirmed that the tube is not blocked and water will flow in and out of the dishwasher through the tube. I plugged the dishwasher in and ran it and it seemed to be running better (quieter, as it had been making some noise previously) until again after about 20-30min it beeped and showed the SE code blinked on the screen.
From what I have read, I think it is probably the drain pump? Since I am confident the drainage pathway is free and clear, what else could it be?
M/C: DMT800RHS/XAC
M/C: DMT800RHS/XAC
