Does an extra 18 ohms matter on a microwave fan motor?
BigKetchup
Las Vegas
The manual says that the fan motor terminals should produce 97.4 ohms, but the multimeter reads 116 (that's with the fan still attached if it matters). Should I replace the motor? When I did get my microwave to turn on, the fan did spin and the terminals received 120 volts.
Thanks.
Nope, I would not replace the fan motor if it turns on and runs.
