Door does not lock
grinolot
Perrysburg, OH
MMV4205BAQ
When the door get closed, sometimes it turns on and starts running and it says door not locked on the display panel.
Without pushing the start button?
That's unusual...most just won't go...most don't "lock"
Door switch, door catch, door latch, PCBoard...broken, loose, burnt...would have to be investigated.
Definetly check the door switches/door catches first....if ok the smart board and/or key panal would then be the prime suspect.
