nd_rawlins
- MMV4205BAB
- Maytag
- 6-10 years
My Maytag microwave (mod# MMV4205BAB) does not heat food, but retains all other functionality (light, fan, turn table, display, etc). I performed some basic tests on a lot of components with my multimeter (capacitor, diode, thermostats, transformer, and magnetron) everything looked ok. Then I found that the HV fuse was blown (my unit has 2 fuses). I am worried that a new fuse will blow if I just swap it out...especially if there is something else wrong that caused the fuse to blow.
I tested the door interlock switches and found something strange. The bottom interlock (I think it is the primary) tests normal when the wire leads are disconnected. But when I test the continuity of the wires by themselves (disconnected from the switch) there is about 75 ohms of resistance. Should this be happening? Or does it mean that I have a short somewhere in the wiring?
Thanks in advance for any help!!
