Downdraft fan doesn't work anymore - help finding diagram for stove keypad panel
paascal
oh canadaaa
Jenn-Air
hello,
the downdraft fan doesn't work anymore. i took it apart, no signs or visual but components.. Worse came to worse i would like to simply put a switch to "replace the button" on the keypad unless one of you know how to clean that touch pad. the number pad partially works.
1. im sorry, i cant find the sticker show in model number and seems no store or even jenn air themselves can help.
2. i would love to have the pinout for the keypad to be able to confirm its working and them jump the leads to test the control board and make sure the fan starts
could anyone give me a hand?
thanks a lot!
Pascal
i took it appart, no signs or visual but componenets.
I don't know what you were trying to say there. Did anyone try testing the motor windings for continuity or powering the motor directly to see if it's capable of functioning?
That wiring diagram looks to have only been used on one model of range (in 3 different colours) model JES9900BCB20 JES9900BCS20 and JES9900BCW20. Manufacturers don't often provide the 'keypad matrix' but I found the one for that model.
i cant find the sticker showin model number
The identification tag on that model should be behind the lower access panel on the front frame of the range.
JFYI
