DPSB613ED2WW GE Dryer SQUEAK/CHIRP NOISE
Chris1981
Texas
DPSB613ED2WW
My GE dryer is making a squeeking/chirping/scraping noise on every revolution. I assume it is the drum bearing? Anything else to be checked and new parts ordered along w/ the drum bearing?
Hi Chris,
These parts below are most common to fail for this problem you're having. I've replaced many of these same parts for this noise problem.
Here's the rear bearing sleeve for your model you can order here(Video Included):
WE1M462 Rear Drum Bearing Sleeve
Here's the front bearing/glide assembly for your model you can order here(Video Included):
WE3M26 Dryer Drum Front Support Bearing
You would need to order the slides for it as well, as they don't come with the bearing assembly.
Order 2 of these: WE1M504 Bearing Slide
Order 2 of these: WE1M1067 Bearing Slide
Here's the front bearing kit(comes with the slides and belt and front bearing):
WE49X20697 Dryer Bearing Kit
Let us know how it goes.:)
Sounds good Chris, keep us posted.
