- DRSR495EG8WW
- GE
- 6-10 years
I have a GE Dryer DRSR495EG8WW that has started to fail to shut off in auto/sensing mode. The timer moves and shuts off fine in timed mode, but the timer does not seem to move in auto mode. The dryer gets to normal heat and dries in normal time. Vent is clear.
I was going to start with the dryness control(?) board and go from there, but figured I should check here first. I checked the wetness sensors and they look clean.
Thanks in advance.
Edit: just found this thread with some symptoms and similar model, fixed with control board. Will try that first unless anyone thinks otherwise.
www.applianceblog.com
Thanks in advance.
FIXED - DRSR495EG6WW GE Dryer will not stop on Automatic
Hello, I have a DRSR495EG6WW dryer that will no longer turn itself off when using the automatic settings. If I use the timer, the knob will still spin down so it's not completely non-functional. I opened up the control panel and looked at the control board, I did not see any noticeable damage...
