Dryer blowing but not heating, again!
Tenpointer
Decatur, IL
My Kenmore Elite 11065924401 is not heating but blows. I replaced the thermal cut off fuse after testing it. All the other parts came back ok. After I put the new part on I tested it and the dryer heated up. I put everything back together and my wife started to use it. Not long after she said it quit heating but was still blowing like before. I cleaned out all the lint so there are no clogs. What could cause it to keep messin up?
You're going to need a VOM for testing. First check for 220 VAC at the power cord connection. Then check for 220 VAC at the element with the timer on timed dry high heat.
Yes, I agree with Rick.
Also ohm test your heating element, and look for burnt/bad spots in it.
Here's the heating element for your model you can order here if needed:
Manufacturer part#3387747 is RepairClinic item#525502
Watch this video to test it:
<iframe height="390" src="http://www.youtube.com/embed/wq-3zsiBID8?rel=0" frameBorder="0" width="640" allowfullscreen=""></iframe>
