- PYE2300AZW
- Maytag
- More than 10 years
Maytag Model PYE2300AZW. We bought this used a few years ago. Recently it has had trouble starting with a large heavy load, buzzing longer than normal when the knob is pushed, occasionally needing to turn the load a little by hand before it will start. Now, even with a normal load, the motor will get louder about 2/3 through the cycle with a buzzing sound. As if it's dropped back to the start winding. I thought the motor was overheating and cleaned out the accumulation of lint inside between the filter and fan, but it didn't help. The exhaust ducting is not clogged and flows freely. Usually after the motor gets louder I open the door and let it cool down, then resume and the cycle finishes normally. Sometimes when I open the door the clothes are dry but hot, so I unload it without cool down. If I let a full dried load run on the no heat fluff cycle, it will run over an hour without the motor starting to buzz.
I'm thinking the motor is getting weak and can't tumble a large heavy wet load long enough to dry it and slows down, engaging the start winding. But a new motor costs more than another used dryer. I have not checked and cleaned to motor itself yet because removing and replacing the drum is quite a chore. Any ideas short of replacing the motor or another used dryer?
