Dryer Won't Start
SamLadybug
Pennslyvania
AEQ6700FS0
Frigidaire
My Dryer will allow me to choose the option of what kind of cycle I want and it will tell me how long the cycle will take but when I hit the Start button the 3 lights(that tell you what part of the cylce is currently in progress) will blink and it will beep until you let go of the button. The Dryer never even starts it just blinks.
I Already tried replaceing the fuses but it didnt do amygood. I would Greatly appreciate a Reply ASAP as I've had no help from the Frigidaire website.
Measure the voltage drop between pin #1 and #2 on J4 connector on the control panel. 0 volts- check the door switch. 120 vac- Defective control board.
Yes, I agree with Rick.
Yes, possibly your control board assembly that has gone out.
Its not a common issue we have been seeing here, but a few members have reported this same issue.
Here's the repair manual for it:
Affinity Horizontal Axis Front-Load Washer (6000 & 7000 Series):
www.applianceblog.com/manuals/5995456851_affinity_washer.pdf
<!-- / message --><!-- sig -->Here's the control board assembly for your model you can order:
Manufacturer part number 134557201 is RepairClinic item number 1170677
134557201
Ok, sounds good, keep us posted.
