DU1055XTVB1 Whirlpool quiet partner II dishwasher - it doesn't drain at the end
James28
Vancouver
DU1055XTVB1
Hi, it doesn't drain at the end, I watched your video and replaced the check valve. That wasn't the fix, disassembled it again to be sure there were no obstructions,
it appears to be clear. It will completely drain when the "cancel/drain" button is pushed. I ran a rinse cycle, it appeared to run fine until it came time to drain. I appreciate your assistance
Hi James,
Then when it came time to drain in the rinse cycle what did it do? Was the drain pump running but not draining? Or was the dishwasher dead silent?
Ok,
I'd first check your voltage with a multimeter at the drain pump electrical terminal wires, it should be 120 volts at the drain pump when its in the FINAL RINSE drain cycle. If you get 120 volts and the drain pump isn't running, then its bad.
Drain Pump WPW10348269
When you click the part link to the drain pump you will see a video of how to access it.
