DMA_Boston
- GGW9250PW1
- Whirlpool
- More than 10 years
My Duet gas dryer is heating, but not enough. There is heat - as the ignitors work - but the heat is not enough the dry the clothes. I have tried "timed cycles" - this doesn't help.
Here is what I have tried already:
What is the best way to measure the temp of the heated air, and at what temp should it be??
- Cleaned lint from vent hose all the way to the roof vent, plus inside the machine compartment and around the heating area - there was a lot of lint!
- Removed the thermistor, checked resistance, and it was about 7,500 ohms, so replaced it with new one that had a resistance of 11,000 ohms. The gas flame now turns on for about 5-10 seconds every 60 seconds - consistently. (So the ignitor and and coils seem to be working.)
- I have not tested or changed the thermal fuse, as I don't think that could have failed given the ignitors and working.
- I don't think the issue is with the moisture sensors, because when I use a timed cycle, the clothes are still not dry after 80 minutes (two 40 minute timed cycles)
