DV210AEW/XAA Samsung dryer won't heat up after replacing belt
jhoney
KY
DV210AEW/XAA
Samsung
My dryer drum was not spinning due to a broken belt. I replaced the belt and now the dryer will not heat. It turns on normally, no error codes. It spins properly but won't heat up. I've checked all the connections that I disconnected to remove door multiple times and they all seem to be connected properly.
What am I missing? Please help!!
Recheck the consol settings in case something got bumped, make sure you are in a heating cycle.
Failing that, redo your repair and check ALL connections for the heat and heating element in case something was bumped during your repair.
jeff sr.
