DV350AEP/XAA Samsung Dryer shutting off and led's fade in and out
krackken
DV350AEP/XAA
Samsung
My samsung dryer DV350AEP shuts off after a few minutes of drying.
When I first start it, it will run for maybe 3 to 5 minutes and then go to 1 minute and shut off.
It does start right back up.
The second time I start it, it will run for maybe a minute or two and then the led lights may slightly flicker and it will just shut off. No 1 minute or music playing.
It will still start right back up.
If I do this 3 or 4 more times, the led lights will start flickering/fading from dim to bright more and more.
Finally it will get to where as soon as I push start, it will just fade and shut right back off.
So far I have replaced,
Assembly bracket thermostat
Dryer thermal fuse
dryer thermostat
thermistor
However, it still does the same thing.
I have also cleaned all lent out from the dryer and the hose.
I also disconnected the dryer flex house to just let it run in the house.
I have not noticed any weird noise or grinding coming from the motor.
Any help or ideas would be greatly appreciated.
