DV365GTBGWR/A3 Samsung gas dryer keeps running 1 minute
Turbo1002
Usa
DV365GTBGWR/A3
Samsung
DV365GTBGWR/A3
I am all out of ideas. This dryer keeps running with 1 minute on the timer. I have changed the main board, thermistor and gas valve solenoids. The clothing dries just fine but the machine keeps running with 1 minute on the timer and the clothing is cold so it does not call for heat while stuck at 1 minute. Please anyone have any ideas?
If you open the door does the dryer stop? Then if you close the door does start on its own without you pressing the start button?
Also run it in NO HEAT/AIR DRY and see if it stops on its own.
Another member had this similar problem, here's his thread:
Turbo1002
Usa
Yes when the door is opened the dryer stops on its own. It does not start back up when the door is closed until the start button is pushed again. Thank you for the link. I have read it and all the components mentioned in it have been changed. What are the odds of the used replacement board from Ebay doing the same? I do not see an option to run it with no heat?
Turbo1002
Usa
One more item I should mention. The tumbler motor was replaced very recently. Could that cause this?
