sbuckner021
- DV400EWHDWR/A
- Samsung
- 1-5 years
Currently there is no sign of power to the dryer.
I've read that these particular models are notorious for burning out even the replacement control boards.
It's also frustrating that there is a protective coating on the main-PCB (a lot of good it did) that doesn't allow me to test/replace particular components directly on the main-PCB.
in the end, i'm just trying to narrow down whether i'd need to replace the MAIN POWER CONTROL PCB or the sub-DISPLAY PCB.
I've attached the service manual for this particular model.
much appreciated,
Steve
[1 week before power issue]
- Power to display assembly/appliance is normal
- Dryer functioning normally
- START button becoming intermittent but still working
[the day of the dryer no longer functioning]
- START button does not initiate a load cycle
- Unplug appliance from the wall for 10-15 minutes
- Ensure breaker isn't tripped
- Plug appliance back in
- START button still does not initiate a load cycle
- Unplug appliance
- Disassemble to access control board and sub-control board (display assembly PCB)
- Measure voltage coming to unit from wall {AC 120/240V) CHECK
- Terminal block connection normal CHECK
- Wire Connection/Condition CHECK
- DC power (@ the high voltage) from main PCB to sub PCB is 11.85V
- DC power (@ the low voltage) from main PCB to sub PCB is 3.26V
- No Power to display panel after reassembling device
much appreciated,
Steve
