DV419AEU/XXA Samsung Dryer Error Code T0
Dbonenfant
Sierra vista
DV419AEU/XXA
Samsung
Hello I’ve read that code T0 could mean it’s the thermistor, I’ve already replaced it with a brand new one and still getting the same code. Any idea what else it could be? Single mom here trying to fix it herself. Any help or advice would be greatly appreciated
Try unplugging the dryer for 30 minutes to reset the control board. If the unit continues to display tO, --->Unplug the dryer, measure the thermistor resistance using a multimeter. You should measure around 10,000 ohms of resistance at room temperature. Replace the thermistor if resistance is off.
If thermistor resistance is okay and the wire harness is intact, replace the electronic control board.
Unfortunately its been discontinued.
