DV42H5000EW/A Samsung Dryer Spinning NO heat
mjmeche
Breaux Bridge, LA
DV42H5000EW/A
Samsung
already changed DC47-00019A heating element, DC96-00887A thermal fuse, DC47-00016A thermal fuse, DC47-00018A thermostat. And Thermister
It was running i timed dry mode in normal sensor mode it would shut off after a couple of minutes.
measured voltage at heater relay on main pcb, black reads 123, blue nothing with dryer off, but 123 when running. but between black and blue nothing
mjmeche
Breaux Bridge, LA
So you want me to jumper the blue and black?
Yes.
I jumpered it, still blowing cold air
New element, new thermistor, new safety thermostat, new thermal fuse, jumped the heat relay....have you tested for proper power to the dryer? 220-240 volts AC from red to black, 110-120 volts AC from red or black to white.
checked power at terminals. It was good
What was the readings?
Static ( not running ) and working ( dryer running ).
I see part of the diagram in one of your pictures, post a better copy so we can see it.
Has anybody checked for power across the element terminals?...from each terminal to the dryer frame?
