FIXED DV42H5200EP Samsung Dryer Main board smoked
Why did you replace the thermistor? What was wrong with your dryer to begin with?
What is the part number that thermistor you replaced?
Jeffs_62
Leavenworth, Washington
I replaced the thermistor because it ohmed at 16.691. The dryer would not turn the drum or heat when pushing the start button. I had no error codes.
I do not know the part number of the thermistor I replaced. It came out of a parts dryer that I had.
Was the parts dryer the exact same model number as the one your working on?
Here's the thermistor for DV42H5200EP:
DC32-00007A Dryer Thermistor
Normal would be about 10k ohms at room temperature, 74 degrees Fahrenheit.
And no I have never seen that control board relay smoke unless you put in a different part number thermistor than what your model takes.
Here's the control board for DV42H5200EP:
DC92-00669Y PCB
Jeffs_62
Thanks Jake.
Yes, the parts dryer was same make and model.
I will double check the thermistor I put in. There was a number on it, and I believe it was f32.
I really appreciate your response. I will update after the new board arrives.
Ok Jeff, sounds good.
Jeffs_62
Got the new board. Double checked the thermistor and it was factory stamped with numbers same as the old one. Replaced the control board and have done a full load running as it had before. I’m going to assume that an issue with the old board caused the fault in the thermistor, and replacing that forced the issue back to the board.
Thank you for your input, Jake.
Ok Jeff, sounds good. (y)
