DV42H5200EW/A Samsung dryer runs, just no heat
tmol
florida
DV42H5200EW/A
Samsung
can a centrifugal motor switch cause a no heat dryer. all other components test good and no error codes . traced red power wire from centrifugal switch to heater element.
thanks t mol
Yes.
Try ( as a test only ) joining the wires together to see if the heat will then come on.
bigbuck
From Planet Mars
The motor has two sets of contacts. One for the heating circuit the other for the centrifugal sense pin on the main board. It senses whether or not the motor is running by watching the state of that set of contacts. The first thing I do on a no heat is remove the top put it in a timed cycle, hit start and listen closely for the heater relay to close, if it does troubleshoot heater circuit. If relay does not close troubleshoot motor switch circuit, second set of contacts. Check continuity of that wire down to the motor, pull plug and look for a bent pin on the motor, pull the centrifugal switch by hand, check the centrifugal switch contacts between motor pins # 5 & 6 and 1 & 2. You usually find a bent pin or no continuity between pins 5 & 6 .
tmol
florida
jump out black relay on new control board. heater came on . but now lost display board will not light up or power on.
t mol
