FIXED DV56H9000EP/A2 Samsung electric dryer drum starts turning even though display is off
AYSF
Woodbridge,VA
DV56H9000EP/A
Samsung
Hi
My Samsung electric dryer (DV56H9000EP/A2) is unplugged at the moment. But as soon as I plug it in, drum starts turning even though display is off. I can turn display on by pressing power button. When I open the door the dryer drum stops turning. Can someone please tell me what the issue could be? I know it isn't the control panel, because I disconnected the wires going from control board into control panel and it still started spinning/turning when I plugged it in...
Could it be main control board issue or a motor issue...? Any help is appreciated.
Hi, It's the control board that's faulty causing this problem
DC92-01606D Assy Pcb MAIN
AYSF
Woodbridge,VA
Ok, thanks Jake. I will give an update after I've replaced the main board.
Thanks again for prompt response.
Ok, sounds good.
Excellent AYSF, glad to hear the new main control board fixed it. (y)
